1. Hi, I have a set of drls, loom and ballasts to fit to my 250, took the left hand headlight out to find these two connectors, anyone know what they are for as they don't fit the drl loom, also is the connector for the drl further down, thanks a9b434648be9ce14d9307510511d4428.jpg ff1e631e652a05fdf05db4a71431cd36.jpg 1311f8829fa77a067fcc766d76427b4d.jpg
    Sent from my SM-G930F using Tapatalk
    Nigelo likes this.
  2. Pretty sure the connector for the drl is down behind the passager headlight somewhere.
    dave77 likes this.
  3. Hi mate the connector in the first picture is the only one I can see down there, I bought the loom off a guy on here dosnt seem to be the right connector on the end of it, that's why id like a pic of the connector off someone who has the drls on their car, thanks for the reply
  4. This is the one I can find it hangs down just beside where the drl goes f4e9d3d7245930cd63d913e1c5476b8f.jpg 6cd180ad9747876fe9dfadba234afa17.jpg
  5. -Jamie-
    That loom defiantly came off a 250 with DRL's, And has the same connector as everyother DRL plug.
    Have you taken the PAX wheel arch liner out and looked behind it? IIRC you cant actually get to the DRL plug from the top
    dave77 likes this.
  6. have the same, the blanked off multi pin in unused, the DRL connector is quite small multi-pin
    dave77 likes this.
  7. and yes need to remove front section wheel arc liner
    dave77 likes this.
  8. Yes mate def the right connector just need to find the loom plug will maybe dig deeper
  9. Thanks for the help bud appreciate it
  10. happy to help, you have v capable car
    dave77 likes this.
  11. Wheel, light and arch liner off, no plug to be seen [emoji848] 6ec770c55f0b7afcedcd90bdeb3cddc4.jpg 3ee2d530216232302dd63c6ffc5769ac.jpg 9133efad06686a0c3ada3d571617b612.jpg 92e86583c27439027108acf26776a6f5.jpg b21919c7c041fe9f6af0b463f899581d.jpg 4e599a3957c7cc4dc61c1d5de04b377e.jpg 7890087e4172a2a7e88351fdb176be12.jpg
    Nigelo likes this.
  12. lol, might well keep going and take bumper off
  13. just read through and see you want to fit DRL's will need to take bumper off for that, dosent vehicle already have DRL ??
  14. No the vehicle does not have them, I have the ballasts drls and loom, there is 2 removable blanking plates were the drls go
  15. Surely the plug wouldn't be hiding in the bumper it would of been in and around the left side somewhere where I looked, thanks
  16. ah ok, so how the end of your loom look like
  17. Which loom the car loom or the drl loom
  18. Doesnt the plug go to the head light on cars without DRL’s?
    dave77 likes this.
  19. Don't know bud, I've not heard that before, any info on it
  20. H
    The oem LED driver (Power Supply) is mounted on the inside of the bumper itself very close to the headlamp washer jets. You will see a square unit mounted with 3 screws on the bumper
  21. Is that the ballasts? I haven't them put into the car yet, the loom I have plugs into the ballasts and the other end is near to go into the car loom, there is no connector on the car loom for it though l, thanks
  22. If you don’t have any plugs on either the bumper/crash bar or in the arch liner then You may have to make up a loom with a live feed from the headlight DRL. Looking through old threads it’s not plug and play. Least you’ll need is a multimeter and a little electrical knowledge.
    dave77 likes this.
  23. So I suppose I could cut the plug off then and just tap into a live and ground, any links for the old threads, thanks
  24. If you type megane 250 DRL retrofit into google they’ll come up bud. Let me know how you get on as I’m interested in fitting them to mine.
    dave77 likes this.
  25. Thinking that the drls in the headlight wiring might work to power the ballasts need to check it out
  26. That's how I got mine to work!
  27. The loom plugs through,
    Off memory you plug the car loom into the drl loom which then plugs back into the headlight
    Search some of my posts
    dave77 likes this.
  28. Thought so, thing is I have no plug in my car to plug the drl loom into lol
  29. I wonder if there is an extra mini loom for drl equipped cars, just a small one to connect between main loom and lights to provide that connector.
    I wish there was an easily accessible parts diagrams available online to check my theories!
    dave77 likes this.
  30. Me too, there is very little info on these cars online, it's v frustrating
  31. It's not obvious at first, took me a while to work it out (I'm a spark too!)
    My drl loom was plugged into itself, so it didn't make sense initially, memory is proper sketchy to how it works but it's something like this (was a few years ago)
    There is a multi plug underneath the headlight somewhere - male pugged into female connector, split this the you need to take out the headlight feed, plug it into that loom, then the plug your left with plugs back into the headlight
    Same for both sides
    Bumper off job really
    dave77 likes this.
  32. dave77 likes this.
  33. GUYS IF YOU CHECK www.catcar.info you can find all the loom diagram you need and part number for them too.
    Nigelo likes this.
  34. Gonna attempt this today, bumper off,and get a proper look, hope I get them running lol
