Yellow RS250 cup
Discussion in 'Megane Projects' started by -Jamie-, Jul 23, 2013.
  1. Charlie Howard
    Ah right, a map would sort you then.
    I'll be curious to see what Jamie thinks when he gets his running again. I can't remember if it was on here but I remember seeing that someone prefers their hybrid Meg over the big turbo forged build because of the lag
  2. -Jamie-
    That'll probably be the white one Matt West owned for a bit which was originally built by my mate up here. It was well spec'd but the turbo chosen wasnt the bets imo and it wasn't as responsive as it could of been, but then the Td04 on the Megs is very mid range orientated and responsive.
    Saying that, the new G25s are very, very impressive for response. Only need to look at Karl's MK2 that had the 550 fitted and the curves. Mine should be similar , maybe a bit more topend depending on cam choice and should spool a bit sooner due to VVT 774369b6e6804585034228a1d5fb88d5.jpg
    ianplymouth likes this.
  3. I have been down the hybrid route, next time it's going to be a big turbo, maybe not silly horsepower turbo but a purpose built one
  4. Going to look at the 550, but i think it will be a bit much, a 450 one would be better if they made one :laughing::laughing:
    To be honest, i had a passenger ride in Karl's old car and it wasn't as on/off as i thought it would be, certainly pulled link stink though, Simon's dad was driving my 265 and we didn't over take him :laughing::laughing::laughing:
  5. Charlie Howard
    Any idea what cams you'll be using? What's the advantage of Clio cams over the Meg?
  6. Clio cams are cheaper than say Catcams :laughing::laughing:
    Priced up Cat cams, new valves, springs and that was a grands worth and for maybe 5-10 hp, not really great value for money.
  7. -Jamie-
    Cams free up a lot more than that with a big turbo, I'd be lucky to see near 450 on stock cams BUT Clio or catcams will see closer to 480 flat out
    The 550 won't actually do that on a 2.0 4 pot anyway, realisticly it's a 500max, the 660 would probably do 550-600 flat out on our engines with enough revs and boost
  8. Torque and power curves look good on that graph so it's an option i think
  9. -Jamie-
    By all accounts they are more responsive and spool quicker than what was the benchmark turbo, the GTX2867. Even the 660 has insane spool and my mate who runs one on his trackcar almost convinced me to go that way and aim for 500 with the turbo not being pushed
    Which I'm still in two minds about
  10. sounds good Jamie, be good to see it all running in May at the ring :laughing::laughing::laughing:
  11. Charlie Howard
    What can these engines safely do when forged? Stock is around 400?
  12. I think the limiting factor is the Woosner Pistons, there rated to 600hp, PEC rods are rated at 1000hp or 9000rpm, must be a safety factor so might get away with a bit more :laughing::laughing:
  13. -Jamie-
    Yeah, May 2020 Ian
    Charlie, will take as much as you want if you spec it properly, there's a French one with 700+, OE internals seem good for over 400, Pistons are supposed to be good for 500, Rods are the weak link again but keep the torque sensible and there's no problems on stock internal
  14. Charlie Howard
    700, Jesus. I guess the turbo is the biggest limiting factor
  15. -Jamie-
  16. Charlie Howard
    I'll take a look tomorrow, not working on my phone.
    Drop the Clio V6 engine Jamie, boost that :tearsofjoy:
  17. Its a date then, i'll start saving :laughing:
  18. -Jamie-
    I was hoping to maybe have it done by year end and get a winter TD done but by the time I've added up all the other bits and bobs needed it probably won't be this year
  19. -Jamie-
    Got this at a bargain price, both brand new and never fitted at a good saving to what Nortech wanted direct c6d982e9a2e1920654aa9ff4587cf7b8.jpg b98a4c68210131e3a767dd666daf5e1d.jpg
    mavez and trickmansa like this.
  20. Charlie Howard
    That's a piece of art
  21. Charlie Howard
    I'm curious, could you fit a 265 ECU and have normal mode remain stock power and then get your full 400-450 whatever you go for in sport mode?
  22. -Jamie-
    Wouldn't need to, can do that to any MK3 but it's a bit pointless imo. The whole reason to having different boost/power settings it to cater to the conditions. So able to run ESP/TC off but then have the choice of low power up to full power if its wet etc.
    With my build and cams there is a possibility that the setup could do well over 450 flat out but I'd only run that at places like Spa/Silverstone etc
  23. Charlie Howard
    Oh didn't know the 250 was capable of that. Always wished my map was done like that. Would be nice to have more than 2 maps though
  24. Sportmode is merely a torque limiter.
  25. Charlie Howard
    In the 265 and 275 it isn't. Normal mode is 250 and sport mode gives you the extra power
  26. My 250 is that way. Great for just pottering around without sport mode then when u fancy a hooligan moment flick sports mode and theres away lol
  27. -Jamie-
    If anyone knows someone looking for a well sorted track MK3 send them my way.
    Can either be sold as is, or with a working engine with recent belt service etc.
  28. Charlie Howard
    Oh no you selling up? What you getting?
  29. -Jamie-
    Not sure yet, looking st options but there's a trackspec M3 possibly to replace
  30. Charlie Howard
    Can I buy your xenon's?:tearsofjoy:
  31. Have you thought about a mk3 mx5 then a trip to Blink Motorsport for their supercharger conversion? https://www.blinkmotorsport.com/blink-motorsport/optimized-supercharger-package/
    Get them to add a set of Ohlins and big brake upgrade and you'll have an extremely capable motor. Hell, if you're a good enough driver even a fairly stock one can embarrass most things
  32. Charlie Howard
    A serious thing to mention about the MX-5. I'm only 6 foot but I couldn't sit in my mates comfortably without the roof down so I wouldn't recommend if you're 6 foot or taller.
