XENON Headlight strange fault
Discussion in 'Electrical & Interior - Security, ICE, Wiring Loom' started by Dávid Márta, Mar 20, 2021.
  1. I have a 2010 Megane 3 RS. My problem is i had an accident and my front damaged, I rebuilt the car, bought good condition black colored xenon headlight. I get error code DF016 Headlight motor circuit, Right hand directional.
    The front right headlight doesnt make the movement left-right, only up and down.
    I have friend with another 2010 megane rs, we put its front right headlight, and fault code disappeared.
    I was sad, i thought the guy who sold me the headlight cheated me.
    After a lot of trying, i made a test, with my headlights, swapped the right to the left, the left to the right, and i saw, the "faulty" lamp made the left-right test movement on start up, but now the other headlight not made the movement.
    So i know, the car is good, because with my friends lamp i didnt get error, worked fine.
    My black headlights are working good if they wired to the left side, but on the right side both lamps failing to move left-right.
    The lamps are from a 2012 car. Is it possible i have to do initialisation with clip, or ddt4all?
    Can you please help me finding solution in this? I pay for the solution.
    Thanks!
    David from Hungary
