Window switches
Discussion in 'Electrical & Interior - Security, ICE, Wiring Loom' started by Ashley, Jul 4, 2017.
  1. Hey guys
    Both my window switches driver and passanger don't work 100%
    Basically they work when pushed down half way but as soon as you push the switch fully down the window stops going up or down
  2. Sounds like they need resetting.
    Have you had the battery go flat or removed it recently?
    It's something like - wind the window up to the top and carry on holding the 'up' button for 10 seconds, then wind it to the bottom and hold the 'down' button for 10 seconds.
  3. just hold the windows switches for 10-15 seconds with the windows fully closed.
    thats it and job done
    Leigh likes this.
  4. So is it hold them with the widows fully closed for 10-15 secs or is it hold them fully closed and full open as Leigh said ?
    Thanks for the replys guys
  5. I think I did both, as I said, but it's possible that I just reset them at the top (like tof73 said) and taking them to the bottom didn't do anything.
    Just try it at the top first.
    Either way, it's not going to harm anything.
  6. Thanks mate il give it a try on lunch break I hope it does fix it as both the passager side and drivers does it
  7. It sounds like it might sort it.
    So has there been a break in power from the battery?
  8. just at the top will reset all the position in regulators and door module.
