https://www.ebay.co.uk/itm/4-x-Team...rentrq:85715eaf16b0aadad8a3318cffc8f090|iid:1 Will these fit the mk3 265 meg? I spoke too Demon tweeks and say have be careful with some the TD’s as can catch on hub face ? Anyone bought these ?
I'm sure they will fit would be better if the offset was more like 50 or more I have some and mine are ET50 they rub very slightly on absolute full lock. I broke one wheel on a friends car, the centre was not deep enough and as i was torquing it up the centre broke out, so be careful if you buy them. Mine were very slightly tight, so i ground the hub down slightly.
tweeks phoned me and mentioned the same thing after i ordered mine Apparently some meganes randomly had a slightly longer lip on the hub, and the centre of the wheel isnt deep enough which causes the wheel to crack once torqued up Just test fit one before you have tyres etc fitted and make sure it sits flush on the face
