Wideband Location
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by MJ57, Apr 2, 2014.
  1. Has any one replaced the secondary lamba sensor with a wideband and used the analog output from one of those.
  2. I had an innovate lambda sensor in mine.
  3. Yea I have an mtx-l innovate just need to fit the sensor at the weekend now.
  4. Track Focus Direct
    Track Focus Direct RSM Trader
    I've just welded a bung in my downpipe for a Zeitronix ZT-2.
  5. Think I'll just put it in the 2nd lamba hole as I run a decat anyway.
  6. Track Focus Direct
    What's the common location for passing cables through the bulkhead ? I was thinking of somewhere under the brake servo to the back of the glove box.
  7. The large grommet is a pita to get anything through. I made a new hole for my gauges.
  8. Can you remove the 2nd lambda with no running issues?
