250 Which Spark Plugs
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by paulashy, Aug 26, 2015.
  1. The plugs on my RS250 need doing is it worth changing them for different plugs from standard as the car has a stage one remap from RS tuning or will standard replacements be fine?
  2. OEM plugs from Renault.
  3. Thanks any idea on the gap they should be set to?
  4. ive got some ngk that i got off ebay to go in mine
  5. If you use OEM you should be fine with the gap they have.
  6. As above, they come pre-gapped. :smile:
  7. Cheers Lads
