275 Which panel filter?
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Cribert, May 25, 2016.
  1. so I'd like to stick an aftermarket filter in my 275. What's the general consensus? I realise I won't get more power but would like a bit more noise. Ktr do a panel filter as do bmc and itg. What are folk going for on here?
  2. I purchased a Ramair panel filter yesterday, it's still to arrive so can report back then :smile:.
  3. I went for a k&n
    Sounds lovely, nice and whistley
    Normally I'm an ITG man, but from what I can see they don't make one for the mk3?
  4. I've got a k&n in my 250, can hear it inside with the foam taken out if radio off
  5. Ramair here. Removed the foam and it sounds good.
  6. Cheers guys. I'll look into them. £50 for a panel filter is silly money so don't want to get one where I won't hear a difference
  7. I purchased my Ramair from their eBay shop. Offered them £23 and they accepted it with free postage. Bargain compared to the ktec and itg equivalent.
  8. Nice one! I'll look at that definitely. Cheers man
  9. £50 isn't silly money for a panel filter that's designed to be used and washed/cleaned for many many years :wink: (K&N)
    If its purely noise you want then a cone would be better for that.
  10. matt e
    Your not going to get noise with a panel filter
  11. No panel filter will make any more noise than the next, so long as its in a standard airbox :wink:
  12. Disagree.
    I removed the foam and put a ramair filter in and the noise did increase.
  13. Don't get me wrong I'm not expecting it to sound unbelievable but maybe a bit better would be good. Removed the foam and noticed a small improvement in noise. IKs are too expensive
  14. I have a BMC yes you do get a suck noise, never as good as an induction kit, but half the price and 10 times easier to fit
    Sent from my Nexus 7 using Tapatalk
  15. Similar here, get a bit more noise on power but more you can hear the BOV venting when you come off the throttle. Doesn't sounds too pikey I think.... Kinda got used to it though too.
