Wheel offset for stock suspension
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by evenflow88, Nov 28, 2016.
  1. Dear all ,
    Do you think a 18x8.5" with offset of 33 fit a stock megane with stock suspension? I am worried it may rub during track days.
    Thank you
  2. What megane is it?
    I only know the offsets etc. for a Mk2 Renaultsport (225, R26, R26R) Megane. If it's one of those, I doubt they'd fit - the wheels would poke out of the arches 43mm more than the OEM wheels - that's a big difference!
  3. Opps , it's a megane RS 250 MK3
  4. Ok - I still think they'll poke out of the arches too far - hopefully someone with some real world experience will come along shortly!
  5. OEM 18x8.25 ET 65
    Your new wheel 18x8.5 ET33
    65mm - 33mm=32mm. Not taking in to consideration the extra wheel width (.25).
    I would say, no.
  6. I have 8x18 with a et42 offset and they are flush with the wheel arch on 225 tyres..pretty much the limit really.
  7. I disagree, I have 18x8 Et38 and they fit fine.
  8. Thanks guys appreciate your feedback
  9. No they won't fit I've tried 18x8.5 et30 with 3 degrees of camber and they still where too tight
  10. ha ha..ok..you can go 4mm more then!
  11. Different cars I think! You've got an R26, right? These boys have a Mk3 Rs, which gives them a bit more room to play with.
  12. That's what she said. Budum'tishhhh
    MartijnGizmo likes this.
  13. what's the minimum et to go with 8.5" wheels on stock height setup without lowering?
  14. in this weather ,4mm is all I have to give!
    Bowen likes this.
  15. I personally would stick to something in the 40s offset wise
  16. thanks will look for some new ones then
