Wheel nut spinning
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by sen, Sep 3, 2017.
  1. sen
    sen
    was going to attempt to change my passenger side swivel bearing but one of my wheel nuts is just spinning and won't come out.
    Is there any way to sort this and once it is out, will I need to get a new hub or is it more likely the nut will be damaged? They are looking pretty knackered.
  2. Has a look online, most people say you will need to drill it out, some else suggested removing all the other nuts and see if a hard tug helps or get someone to pull on it whilst you try and unscrew it
  3. sen
    sen
    Guy at the tyre place got it out for me. Is it possible to retap the hole in the hub that the wheel bolts screw in to? Gonna need to buy a new hub if not.
