250 Wheel bearings
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by Dazzler32, Jul 1, 2014.
  1. Hi guys,
    I'm getting a a rumble from the front between 50mph to 80mph plus my mpg has dropped a bit so suspect the wheel bearings.
    Has anyone replaced their bearings before? Are they the bolt-on or the press type?
    Cheers Daryl
  2. It could be wheels out of balance
  3. My tyres are about 3mm so due to be changed shortly so I'll swap them over first and get the tracking done as one tyre has worn unevenly. If that doesn't cure it the bearings are the next port of call.
  4. Bearings bolt on. I have 1 off a car with 22k miles if you're interested?
  5. How much?
