  1. 7.2mm, you'll be lucky that's more likely over 2 tyres not 1
  2. Surprisingly the depth varies with tyre size. For a 235/40 18 inch its 7.2 mm. Remember Michelin added an extra 20% more depth for the Cup 2.
  3. The cup 2 tyres are not that extreme looking tyre to say a cup or cup+ , I'll now better when they get fitted as there at the garage wrapped up at moment so have not had a god look at them
  4. -Jamie-
  5. Flip that looks great mate!!!!
    Seats look fantastic for getting to and from track as well
  6. mie
    mie
  7. Looking good. Are you keeping the regular seat belts in?
  8. -Jamie-
    Thats coming at the end of the year
    Nah, Harness only. Bit of a pain but it doesnt get used everyday, Maybe once or twice a week so its bearable
  9. -Jamie-
  10. ^^^Looks ace. Cage next?
  11. -Jamie-
    Probably at the end of the year once I get myself something nice to use as a "daily" nice 3 series touring or something similar that gives me the option to tow
  12. My powerflex black series lower engine mount arrived today. :smiley:
  13. Washed the Mrs daily banger. Not bad for 11yrs old and 179k
  14. Gave mine another full detail and wax today she looks immaculate I love it
  15. Fitted a set of Goodridge brake lines and froze my nuts off in the process lol
  16. NJH
    NJH
    Been having a splurge on parts recently, got a set of Brembo HC disks, Mintex pads and MrPink pins for the front. Chinese cooler (link from Andy Bond) and Cooksport springs. Blooming freezing out so its all sat in the dining room, likely just get Paul@Tech-1 to fit it all for me.
    Anyone thinking of doing the MSE days at Hullavington coming on in a few weeks? The land has been sold of by the MoD for housing so may be our last chances to get on that track.
  17. matt e
    Cleaned both cars for the first time since November
    Went for a drive with my mate in his scooby and waved goodbye to him in the rear view mirror
  19. Got a pic of the bucket seats in the meg mate?
  21. Went over 60k miles! Next up is new engine mounts and gearbox mount insert and caliper dust seals. Then having the rear quarters re sprayed and protected and she should be ready to sell to make way for a 265!
  22. Thanks for pic, i like them alot, there relatively cheap as well arnt they
  23. Really cheap mate £300 new for the pair with runners, I prefer them a lot compare to other bucket seats
  24. Did you go with the standard size or go for the wider ones?
  25. Wider ones mate
  26. what they like? i had some recaros bucket seats and they was tight as a nun lol think im gonna take the plunge on em
  27. Their really good, actually really comfy on long journeys. I went to spa with them fitted and probably the last half n hour they started to uncomfortable which I think is really good.
    I'd much rather sit in my seats then the girlfriends Clio 200 seats (non recaros) on a long journey.
    I'm 40-42" waist and I fit in fine lol
  28. ianplymouth
    I have also got a set of these fitted, in wide format :smiley:
    Not had chance to drive it yet, first long trip will be to Bedford
  29. What frames you used to mount these Ian?
  30. -Jamie-
    Mine was dropped off today for Belts and a new Slave and Clutch. Got a top spec Skoda to smoke about it, Bi Xenons are brilliant.
    Also in the process of calibrating it so i can get switchable maps on the various throttle maps through the RS monitor, LC, Race ESP and whatever else we can come up with and get working.
  31. ianplymouth
    KTR subframes, i did remove the side mounts and sliders they came with, turned the side mounts around and refitted, because they are the wide ones i had to drill 2 new holes on the outer sides of both subframes.
  32. On the tunnel (inner) side what did you mount the lap belt to ? Did you drill into chassis or secure to side mount plate ? Also for 5th strap, did you drill chassis under seat or attach to subframe
  33. ianplymouth
    I drilled through the side of the tunnel opposite to the outer fixing, made some plates, drilled and tapped to 10mm, put the eye bolts through and screwed on the plates, awkward to do on your own as your arms will be too short, a screwdriver through the eye and a weight to hold it in the hole worked well, plate i used was 10mm thick.
    I have six point harness's, so i wrapped the belt ends around the subframe, same as you would do around a roll cage bar, i protected the edges with some thick 1/2 inch hose split length ways and taped around to stop them falling off, it's a bit tight to do but i think it's worked out well.
  34. matt e
    added a v6 to my collection :tongueout:
  35. yh that is good to be fair, i remember first time driving my r26r home, was fine for 1st hour then my legs and bum went numb, my steady ride home turned into a quick dash home before i became paralysed lol hoping they will be ok to get to the ring and back with regular stops for a stretch. all i know is nothing can be as bad as vauxhall seats, rather sit on nails.
  36. when you going bedford mate? 27th of this month? if you are il be the one drooling through ur windows eyeing up your seats lol
  37. ianplymouth
    Yes i will be at Bedford on the 27th, you drool over my windows make sure you clean them after :smiley:
  38. Last night i did a Brake flush using Ate Type 200 and put my front grill back on the front of the car.
    I also carried out 6 month oil and filter change
  39. Bit of a wash aswell
  40. Simple mod, removed the parcel shelf. Brrrrrrr pop bang pop pop brrrrrr bang pop pop.
