Yesterday my car was treated to new discs and yellow stuff pads, 2 new boot struts and a second splitter under my ownership. After driving without a splitter for a few weeks it's amazing how much it finishes off the front end and the boot struts now mean I'm not going to do myself any damage as it opens all the way.
Just fitted some of them super white bright bulbs and LED sidelight bulbs, wot a pain in the arse the main beam bulbs are to get at. lol
New engine mounts delivered, cheers Adam, booked into diamond motors for fitting on the 5th, and booked into rstuning for 630 injectors and a 3" decat map tweak. Can't wait
Bought a set of solid engine mounts and powerflex bottom mount! should be interesting vibration in the cabin now...
Had a tidy up of my washer jet hose and got new number plate lights but looks like a new loom is needed too :-(
One of my plate lights was like that I got one of someone breaking a meg and just soldered the wires and heat shrinked them if you can find some it's a cheap easy way of doin it without replacing the whole loom
Spent several hours cleaning the arches and painting a few little bits to tidy the wheel wells up. I painted the centres of the HC Brembo discs and did the droplinks after this pic was taken. They're not perfect but alot better than they were!
Luckily I managed to buy a back box that had already been done from a member on here who'd just bought a megane with it done and had reverted back to a standard back box. So I literally just had to cut the back box off and slide the new part on. Apparently a power flow place will do it
serviced the DV bought some parts for my DIY ITG intake and fitted a Cupra Front Splitter, oh and bagged an RS Tuner box
Btw folks- worth checking where the plastic bit on the boot rubs either side. I only noticed as I was changing the loom over.
bumper off re-secure crash bar replaces bumper clipping bracket under N/S headlight sidelight bulb O/S engine oil + filter box oil cabin filter wipers screenwash tracking to rectify LHDown safety inspection of tyres/brakes/general bolt check move his vis from boot to cabin! Ready for the ring!
Botched a fix for the bracket for the front bumper. Hit a kerb the other day and it popped the bumper off at the left hand side.
