Twice now I've locked my car and my passenger window has come down on its own. Getting it back up I've had to remove and insert fuse, double lock car and repeat (x10 approx.) Also my passenger do it well is wet, Not sure how the water is getting in but are these 2 issues linked? Is there something in the passenger do it well that controls the windows? Any idea what could be causing the wet floor and also any way of sorting the window? Thanks in advance.
Also make sure the door drains are clear. The door speakers can sometimes cause problems, make sure they are sealed. also check air con drain. There are details in the HOW TO section.
OK thanks. I've had curtain wire down the scuttle drains and they seem OK. Pulled a load of dry leaves from being the air con unit when I removed the pollen filter but didn't know how to check the drain
