Hi all. I'm looking to save some weight (from the car). I always remove the seats and boot lining but looking to go a bit further. Is it possible to remove the noise insulation from the floor? Has anybody done it? Any other ideas would be gratefully received
Is it a big job to get rid of the floor sound deadening? Is it possible to refit the carpets afterwards? Cheers.
Glovebox, underfloor tar deadening (or whatever it is), clio battery, engine cover, engine sound deafening will save a bit but getting the seats out and replaced will be the big un. OEM numbers a re SO heavy.
Piss easy if you remove seats which is four bolts per seat. Watch how you butcher the foam under the seats though as it holds the carpets shape. If you're not bothered about that though just go wild.
Yep its for track days but still use it on the road so cant go too crazy! Is there much weight to be saved from removing the floor foam? So far on my list is the cd changer, rear wiper, engine cover/insulation, spare wheel, and all seats apart from driver!
Ah, fog lights, good idea! Will keep my eye out for second hand seats Cheers guys Sent from my GT-I9100 using Tapatalk 2
Doesn't removing too much weight adversely affect the mechanical grip of the car on the road, particularly the rear making it tail happy
can do, i slapped the cage in which helped. Pull weight from the front too and its not too much of an issue.
