Water leaking inside??
Discussion in 'Electrical & Interior - Security, ICE, Wiring Loom' started by max.marrion, Jan 25, 2024.
  1. Car: Megane rs265 2015
    Hi guys,
    I’ve noticed that water has been getting in somehow and sometimes making the carpet damp. It’s coming in from the passenger side and usually after it’s rained I’ll open the door and there will be a puddle on the door seal.
    i have checked:
    -door membrane (no rips all dry)
    -scuttle drains are clear and I ran water down them and they are coming out the bottom of the car.
    -door drain holes seemed clear and not blocked.
    im wondering if there may possibly been something I’ve missed.
    I will post a photo of where the water is sitting. Thanks all:smile:
  2. Would defo say door membrane not sealing correctly or the rubber around the plastic door card clips are damaged/not sealing correctly. Usually see water marks coming from one of the clip holes or wheres its leaking from if its the membrane. Keep the door card off for abit, taking the clips off the card and plug the holes. See where its coming from.
