Hi all for some odd reason my R26 has started collecting water in the passenger door pocket. Has anyone had this before in there Mk2 Megane? Is there an easy fix?
Remove door panel, remove speaker, seal and refit speaker, make sure the drain holes in bottom of door are clear, make sure membrane is sealed properly, this should probably fix it.
The speakers have a protective cover..check that's not cracked or been cut out to fit larger door speakers.. Sent from my Pixel 6 Pro using Tapatalk
