Warning Message Battery Charging Fault - STOP do not pass go or collect £200
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Deepster, Oct 1, 2014.
  1. Ok made the last bit up, but I had this message flash up breifly on the dashboard and then disappear.
    Other than what it says on the tin, any ideas what the underlying fault could be ?
  2. Alternator issue ?
  3. Can happen if the engine nearly stalls from a lazy pull away, it will briefly flash up?
  4. Cheers will take that over a repair bill
