Hey I have a problem. My car is MEGANE RS 265. Auto vibrates from the beginning. The vibrations are when I start driving, low and high speed , loaded and not with weight. The car is on a very low H & R suspension, it has installed a distance of 5 mm to the driveshaft. I can hear a click from the left wheel. The left side of the driveshaft has a large clearance I bought this car and the seller said it was a normal vibe with a sport suspension. Wheels are ok. Tires are ok. Vibrations are only when adding gas. And what do you think? Did you have such a case?
Have a look at this thread. New driveshaft sorted my vibration. http://rsmegane.com/threads/driveshaft-inner-cv-joint.14821/
When you start to hear the car, click on the left wheel Tomorrow I go to a specialist from driveshaft
