Vibration under acceleration
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Ken, Jan 9, 2022.
  1. Ken
    Ken
    Hello all,
    I have a mk3 RS.. recently lowered it on KW V3 coilovers, but I have noticed vibrations coming through the gas pedal and steering under acceleration.
    After doing some research I am quite convinced that they came from the driveshafts, and these are my questions:
    1) Should I be worried & can I ignore it (though it's annoying)?
    2) What would be the solution in fixing the issue?
    - New driveshaft?
    - A new part within the driveshafts, the O ring or something I believe?
    - Driveshaft spacers?
    If you had similar issues before please point me to the right direction. Thanks
    Ken
  2. Try raising the front up a few mm. I tried everything to cure the issue on our old 250, and raising it 10mm cured it.
    Ken likes this.
