Vibration between 2.5k-3k revs
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by pearcyy, Nov 10, 2014.
  1. Hoping you guys can help me out.
    No matter whether stationary or on the move, I get a 'metallic' vibration betwen 2.5-3k revs. It disappears over 3k revs but if you change gear and the revs come back through that band then it vibrates as it passes through.
    If it was a constant vibration I'd assume it was a heat shield but as it's only between certain revs, I haven't a clue what it could be. Could the turbo be on its way out?
  2. Check the heat sheilds all the same, vommon gor them only to rattle at certain revs
  3. Yeah I would go with Ryan, did exactly the same on the wife's motor.
