Vibrating from drivers wheel under load at 50
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by Bilkos, May 30, 2015.
  1. Any update?
  2. Waiting on my decat before any work.
  3. Well the plus side, the 250 DMF / 225 clutch combo compared to the latest R26 setup is like night and day. Downside, wobble is bloody still there!!!! Slightly different but there none-the-less. Gutted. Noticed there's a lot of movement in the engine mounts....
  4. And if you build the acceleration up to 50 and beyond rather than hit it hard, doesn't do it....
  5. Is it boost related? If so could it be pinking? Could you have a weak coil pack?
  6. This still not sorted after about 6 weeks ?
  7. TimR26
    Have you taken the car to a renault specialist to get checked out?
  8. Yes and Yes....
  9. So it's sorted then, what was it
  10. I wish. DMF changed which was knackered anyway. It's strange cause it's better but has changed. If you gradually build the acceleration, you don't notice it but if you accelerate hard, the wobble come on.
  11. Which is why I've asked if you are sure it's driveline related and not a misfire under load?
    Have you checked inner driveshafts?
  12. Still doing it, mechanic suggesting it might be diff?
  13. Changed engine mounts which have definitely helped. Still there though but much, much lesser so...
  14. Interestingly, if your press the accelerator progressively you don't feel it, but if you stick your foot down, the wobble is now 70 and not 50mph....but you drive through it???
