(Very) Annoying Buzzing noise coming from inside cab.
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Cavell07, Jun 9, 2015.
  1. Hey guys, started to get on top of several issues with my 225. Noticed an annoying buzzing noise (no not a fly) in the front towards the windscreen in the middle, sounds lime some sort of electrical buzz but haven't a clue what it is, anybody had a similar issue? Any help would be appreciated before I have to take it to Renault.
    Paul.
  2. It will most likely be the foam strip rubbing against the window, spray so.e silicone lube or wd40 down there
  3. Climate control fan thing behind the rear view mirror.
  4. Yeah, quite common to be the little fan. Pull the surround off the mirror mount and you should be able to get access and see why it buzzing.
  5. ha ha its the one behind the mirror easy enough to take apart. when I first got mine it almost drove me to smashing it up but I got one for a tenner off here who was breaking their car. You could take it out and try cleaning it with cotton buds etc
