UR Megane R26
Discussion in 'Megane Projects' started by matt e, Aug 6, 2014.
  1. matt e
    Cheers. If you do spray your handles get a set of second hand genuine ones they fit alot better
  2. matt e
    sprayed the door badges again, before they were red writing with a anthracite background
    34665154242_a8941990e0_c.jpg New badges by matt eaton, on Flickr
    34696213001_abb94b5b00_c.jpg Side by matt eaton, on Flickr
    and hopefully i should get my steering wheel soon from snappy
    Big Uno and rTEM like this.
  3. I want those wheels :hearteyes:
    matt e likes this.
  4. matt e
    got my steering back and handbrake, fitted the steering wheel last week but only just fitted the handbrake today as i cross threaded the handbrake cable tension bolt. i also put new cruise control button on the steering wheel as the old ones wouldn't decrease the speed and kept coming up 'check cruise control'
    34068200424_d28305e861_c.jpg Cruise control buttons by matt eaton, on Flickr
    34942785631_a9c0fa9390_c.jpg Retrimmed steering wheel by matt eaton, on Flickr
    got a new trim for the wheel and painted to match the rest of trim and bought a cover for it to protect it from sunlight (alcantara part)
    35067919941_6bc68eb141_c.jpg Steering wheel cover by matt eaton, on Flickr
    34811666130_3c7dfb2360_c.jpg Wheel cover by matt eaton, on Flickr
    with the handbrake ive cleaned it up and sprayed it silver and also resprayed the plastic trim on it
    34524144070_88f4e79390_c.jpg Handbrake retrimmed by matt eaton, on Flickr
    34524136160_7e2dd91c58_c.jpg Handbrake retrimmed by matt eaton, on Flickr
    34524127110_d4c5586205_c.jpg Handbrake retrimmed by matt eaton, on Flickr
    34388651423_722b589f2f_c.jpg Handbrake by matt eaton, on Flickr
    and then lastly i removed the recaro's to give them a proper clean and condition the leather and hoovered underneath
    34388607933_75476b46bc_c.jpg Cleaned recaro by matt eaton, on Flickr
    SiMonster and massivewangers like this.
  5. Some nice tasty bits added there Matt.
    Where did you get the expansion tank from bud?
  6. Pav
    Pav
    i've just read your thread..what a machine!!even though i have a boosted clio i still find this thread very inspirational..sorry about your troubles with your engine but hey ho..its forged now and pulling like a train..
    i've been looking at different intercoolers for my clio..i have a forge like you but some of the fins are,lets say a bit worn..any other brands that you would be able to recommend pls??
  7. matt e
    got it from carparts4less
    http://www.carparts4less.co.uk/search/205740030
    use PAYDAY takes it down to £16
    thanks, you clio must be fun to drive, i know people use airtec
    Trophyboy likes this.
  8. Like that steering wheel. I've been wondering how a suede top/bottom would look in my 265. I'm a bit reluctant to go suede on the hand grip area from a wear perspective.
  9. Pav
    Pav
    yeah know about airtec..was thinking something a bit less expensive..not keen on paying close to a £500 mark again..a few gyus i know use a mishimoto coolers..they go for about a £200..thought you may know something about them..thanks and enjoy your beast
  10. caymanr26
    caymanr26 Events Liason
    Where did you get the clocks done mate?
  11. G'day is the yellow 197 gauge section a copy or taken from a actual Clio‽
    I think this looks great btw!
    I'm not familiar with your other thread you mentioned; if you have more info there or instructions/links‽
  12. matt e
    No it's not taken from a Clio, I had it made to look like the Clio dials. What other are you on about? I'm not sure?
  13. Matt your car is awesome I love it. great read and given me a few ideas for mine.
    matt e likes this.
  14. Your very beautiful car.
    I'm following
  15. matt e
    finally changed my wheels back to standard, i swapped with kieran off of here. i much prefer the standard ones to the ozf1's. they do need refurbishing though and id want them done in a light anthracite like the wing mirrors but thatll have to wait for now though. cleaned it today so took a couple of pictures
    35567514524_ca14965d95_c.jpg DSC_3537 by matt eaton, on Flickr
    36234747462_36a0ddc756_c.jpg DSC_3539 by matt eaton, on Flickr
    36265955391_b530a11790_c.jpg DSC_3544 by matt eaton, on Flickr
    36265982911_969bca4133_c.jpg DSC_3531 by matt eaton, on Flickr
    36402562315_ae47dd83b5_c.jpg DSC_3541 by matt eaton, on Flickr
    36265952111_83c0ae8bf9_c.jpg DSC_3546 by matt eaton, on Flickr
    and also ive fitted the front/rear/doors bumper decals. ive bought some spacers for the car so the wheels stick out a little further
    went with pure motorsport ones, 18mm on the rear and 5mm on the front. i need to fiut longer studs on the rear thought so got them as well
    36067213845_93000f1843_c.jpg Longer studs by matt eaton, on Flickr
    36059911072_f8dff740aa_c.jpg Spacers by matt eaton, on Flickr
    got a set of genuine centre caps for when i do get the wheel redone
    [​IMG]Centre caps by matt eaton, on Flickr
    and something ive been looking at is the fuel system, i dont want a swirl pot or a external pump and aftermarket fuel rails are mega money, i got a mk3 fuel rail, there centre feed so it 'should' help with problems people get with the piston 4 and lack of fuel. dont know what to do with the fpr that the mk3 runs on the rail though
    36067228275_23b7f57513_c.jpg MK3 fuel rail by matt eaton, on Flickr
    35677726960_fa7cc7b999_c.jpg New inlet with MK3 fuel rail by matt eaton, on Flickr
    35567427974_18529499e7_c.jpg Injector clips by matt eaton, on Flickr
    and lastly ive bought a set of MK3 brembo calipers, but not too sure if im going to keep them though, im going to strip them and replace the seals
    [​IMG]MK3 Brembo calipers by matt eaton, on Flickr
    36091100831_3ecfb96f8a_c.jpg Caliper decals by matt eaton, on Flickr
    Big Uno, Ian Hughes and RMDavis like this.
  16. Nice work Matt! This is looking awesome.
    I personally avoided the Grayston studs because I hadn't really read anything positive about them, the Pure ones have been spot on though (bar my issue with the fronts).
    Are the MK3 calipers a straight bolt-on?
  17. matt e
    cheers nick, i had grayston studs on my clio for 3-4 years with no problems and i think ive had them on the meg for a year or maybe more? havent had a problem with them so far. yeay i had the same problem as you with the studs hitting the hub
    14897732048_58f525a44b_c.jpg DSC_0119 by matt eaton, on Flickr
    with the mk3 brakes they need a spacer cause they run bigger discs 340mm iirc and also you need a spigot rings as the mk3 has a bigger centre bore than the mk2 and the discs need drilling as the pcd is different as well but other than that there a direct fit lol
    Big Uno likes this.
  18. Really like it back on the original wheels, they really suit it.
    matt e likes this.
  19. Immaculate as always mate [emoji108][emoji108][emoji108] just need to invest in a stud and nut kit for mine now, will probably opt for the same as yours if you've had no issues [emoji106]
    matt e likes this.
  20. Fair enough mate!
    How'd you sort it? Planning on just grinding a few threads off the end of mine. My only issue with that was potential corrosion.
    Ha, direct fit! :wink:
  21. matt e
    yeah just cut a couple of threads off. could just paint the end in hammerite or zinc paint
  22. Lovely car Matt, and a cracking project!
    A quick question regarding the spacers. 18mm rear and 5mm front? Is that a common setup used for the standard wheels?
    I was looking at mine and noticed the wheels could do with a bit of help filling the arches!
    Sent from my HTC 10 using Tapatalk
    matt e likes this.
  23. Feirny
    Feirny RSM Admin
    Looks great, just like my old one!
    matt e likes this.
  24. matt e
    thanks, not sure what the common spacer size is on the meg. i originally ordered 15mm hubcentric but PMS rung up and said 18mm is the minimum on the meg for hubcentric. ill fit them Thursday and get some pictures
    RMDavis likes this.
  25. Cheers Matt, I look forward to seeing those!
  26. Stunning as usual mate :smile: Can't beat standard wheels in my opinion. I had mine done lighter to match the mirrors better, they took the diamonds off the caps and painted the caps with the same paint so it all matched perfectly :smile:
    Ian
    matt e likes this.
  27. matt e
    fitted the spacers this morning. had to remove the old studs first then clean up the threads
    removing the studs
    36362915191_56111f4b38_c.jpg Removing old studs by matt eaton, on Flickr
    35665091844_f61bef1f45_c.jpg Studs by matt eaton, on Flickr
    cleaning up the threads
    36453781946_c81cd07826_c.jpg Cleaning thread by matt eaton, on Flickr
    36500089895_3ee746fbaf_c.jpg New studs fitted by matt eaton, on Flickr
    once i had the new studs on i put the spacer on and couldn't get it to sit flush and realised it was the bearing cap in the way so had to remove that and i fitted it back on the spacer if thats ok?
    36331777752_568b79c105_c.jpg Spacer gap by matt eaton, on Flickr
    36331780372_9f8e919cfd_c.jpg Cap by matt eaton, on Flickr
    36331774092_24286ac846_c.jpg New studs fitted with spacer by matt eaton, on Flickr
    36454324046_48f487b6a7_c.jpg With spacer by matt eaton, on Flickr
    35665556314_85081cf85f_c.jpg No spacer by matt eaton, on Flickr
    before
    after
    36103215180_333ed15965_c.jpg Rear with spacers fitted by matt eaton, on Flickr
    36453828096_0d69f51173_c.jpg Rear spacer fitted by matt eaton, on Flickr
    36103189510_e2913bd154_c.jpg Front spacers by matt eaton, on Flickr
    36103183240_9c4d0a1541_c.jpg Front with spacers by matt eaton, on Flickr
    also bought new coils and spark plugs
    36453810386_7efbda6a5f_c.jpg New coils ans spark plugs by matt eaton, on Flickr
    RMDavis likes this.
  28. That looks fantastic Matt!
    Spacers and stud conversion for me.nedt month I think! [emoji6]
  29. Love this thread, your car looks amazing Matt!
    I have one small question - how do you get the rear bumper trims out? I've searched but can't find anyone else who has actually done it.
  30. Car looks really good. With regards to the spacers are those the biggest you can go without rubbing anywhere. And do you notice any improvement in handling?
  31. matt e
    thanks, you just pull the trims out from near the tail pipes and they unclip
    cheers, with regards to rubbing i suppose it depends how low you car is. the rear i say you could go to 20mm if your lowered and 15mm on the front but if you want hubcentric i think the minimum is 18mm
  32. caymanr26
    How did you paint the grilles? Did you primer them first?
  33. matt e
    yeah degreased them thoroughly first then used plastic primer
  34. Spacers wont help with handling,will change scrub radius to potentially make handling worse
    Plus adding more strain on the wheel bearings.
    A threads running about this in another section when offset is altered.
    Unless you drive the car real hard,i doubt you will notice much though.
  35. matt e
    there done for 'show' than anything else
  36. I was reading that thread with interest. I will get the geo checked on mine and go from there..thanks
  37. Ah I see. Always nice to fill the arches. I won't bother with them then as I only have an inch each side clearance on the trailer.
  38. Did my rear bumper inserts today, real easy thanks to Matt's advice!
    Had some black plasticote/dip left so used that. Looks new (If it doesn't last I'll primer and paint them properly..)
  39. matt e
    done a couple of small bits, ive finally got the fuel rail sorted so it bolts to the mk2 inlet. but haven't fitted it yet. might do it this weekend. also because im not using the regulator on the rail i got a blank made up to fit in its place
    37382509110_dd4757cbf8_c.jpg Welded by matt eaton, on Flickr
    36777510001_4623598457_c.jpg Under side by matt eaton, on Flickr
    36746702832_ebc94e9483_c.jpg Blank fitted by matt eaton, on Flickr
    ive decided im going to fit a DW65C fuel pump as well as the current pump has done 95k now and the car really isn't standard much now. there's a myth on the internet as well that the non standard fuel will use more power and could burn out the upc and its best to fit a dedicated power supply from the battery. as mine is in the boot its easy to run a new wire for it. ive placed a relay in the boot for it and ive ran the wire to the original around the fuel tank up to the connector for the sender
    37241365100_a2a5138a7f_c.jpg Relay with loom by matt eaton, on Flickr
    36899004903_5e0e5dce61_c.jpg Relay wiring by matt eaton, on Flickr
    and while im there im going to run braided ptfe fuel pipe from the tank to the rail as ive seen a few megane leaking fuel and the line can corrode but im buying bits now and agin for that and probley wont be till next year now and buying the AN fittings isnt cheap! on the rail i had to buy abouts bits just so it misses a vacuum line and the little connectors that make the push fittings to a an6 are about £17 each
    36858812024_a9d7c90a5d_c.jpg Fuel connector by matt eaton, on Flickr
    36858832884_fcbb8219cf_c.jpg Fuel connector by matt eaton, on Flickr
    and because im fitting a new pump i thought it would be better to buy a second hand sender then get it cleaned and it saves me messing around with mine and i can just swap it straight over. had it ultrasonically cleaned by @Trophyboy it came out like new. just need to save up for the pump now or hope i get it for Christmas.
    37868387104_49779b4ff1_c.jpg Clean fuel sender by matt eaton, on Flickr
    38528044596_6c2c3ce021_c.jpg Clean fuel sender by matt eaton, on Flickr
    new gasket/lock ring for the sender
    38552682712_de34979f6d_c.jpg Fuel sender gasket by matt eaton, on Flickr
    and ive been looking for a loudwer exhaust, ktec sell a 2.75" with a smaller back box that fits the milltek pipes (its made by milltek anyway) got it off ebay. when i got it the tips were covered in carbon and when i had cleaned the the chrome underneath had worn and flaked off. so i painted the tips black. they never stay very clean anyway with the decat fitted
    37954530172_bc28d08281_c.jpg Ktec exhaust by matt eaton, on Flickr
    and im going to fit a oil cooler but im going to use a thermostatic one. because theres not alot of room between the radiator and oil filter with a sandwich plate fitted im going to bin the standard laminova type thing ive bought the insert that the 1*2 uses soo ill fit that and loop the coolant hoses together. its only a small setrab cooler that i picked up off ebay cheap brand new. ive had a couple of brackets made up to fit it as well
    [​IMG]Setrab oil cooler by matt eaton, on Flickr
    [​IMG]Oil cooler bracket by matt eaton, on Flickr
    24697860698_dae98b68c7_c.jpg Coolant loop by matt eaton, on Flickr
    lastly im going to paint the intercooler black. ive got some spray paint that you can use on radiators thats still suppose to let heat transfer. i painted the crash bar last week back should look better with a black intercooler although the crash bar is hidden lol
    38534228442_d4cf1967c4_c.jpg Paint for intercooler by matt eaton, on Flickr
    26639676499_d478e37747_c.jpg Painted crash bar by matt eaton, on Flickr
  40. I don’t think anyone has actually measured the current draw from an OEM pump to compare with that of the aftermarket pumps to get real clarity on whether a separate line is needed. It’s quite possible that different pumps will draw more/less current than OEM even if providing the same fuel pressure. They may be providing higher/lower fuel flow rates.
    In my opinion, it’s how much of a safety factor you want to include. Melting the UPC is possible as there isn’t a removable fuse there.
