R26 Upper engine stabiliser bar
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Friggerpants, Apr 17, 2014.
  1. Which way does this fit on my R26.R please?
    Does the circular hole attach to engine and slotted hole attach to chassis or the other way round?
    Also, when changing do I need to support engine or will it be OK resting on the other three mounts?
    Cheers.
  2. Slotted to engine, also ok to hang on the other mounts, engine needs a tug to position it anyway.
    lee
  3. Thanks for that Lee.
    Which way up does it go too, if I'm looking from the front of the engine bay, keyway to the right or keyway to the left?
    Is the keyway actually used/
  4. It is the correct way up in the pic. So key way to left but I don't think it's used, it only bolts through it doesn't locate on anything
  5. Thanks Lee, fitted it today, easy job, 20 minutes with an 18mm socket a mallet and a screwdriver!
    Regards
