Up rated inlet
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Smurf, Sep 10, 2014.
  1. Anyone know where I can get a up rated/Bigger inlet manifold from or made ?
  2. I think that ktec racing has got one
  3. Unless running big power/going to change the throttle body there isnt much point
  4. Engine
    forge fmic
    ktr hard boost pipes
    cp pistons
    cp rods
    arp bottom end bolts
    forge dump valve
    tubular manifold
    garrett gtx3701 turbo with screener pipe into down pipe
    cat cams
    supertech valves
    supertech springs
    solid flywheel
    helix 6 piece paddle clutch
    890cc injectors with custom fuel rail
    botch 044 fuel pump
    swirl pot
    kw variant 3 coilovers
    ap 330mm 2 piece discs
    carbolic c+5 pads
    heli braided brake lines
    turbo smart boost controller
    It's modded
  5. Will.
    Speak with Josh Cook. He might have something from his big engine build. I can't remember what he did with the inlet that he had. Might have already sold it.
  6. Naith
    He never uprated it iirc. He wanted to do a trick one but never pressed ahead as I was planning to have them produced on a bigger scale. AFAIK anyway...
  7. Naith , did you get as far as prototyping ?
  8. Naith
    No nothing, we just discussed it really when I was at his one weekend working on the car. He may have pressed ahead but I wasn't involved. It was along the lines of a central feed splitting symmetrically into a four.
  9. Any gains on a mapped but standard engine do you know ?
  10. Will.
    I'm talking about the big engine build before the one he has at the moment. He sold the engine but not sure if he sold the inlet mani as well.
  11. I thought josh used a 197 manifold and throttle body on his big turbo build? Im sure i read somewhere he chopped the runners and moved the throttle body to the drivers side, then used silicone hoses to connect the plenum to the runners?
