265 Tyre Pressure
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by Illisha, Jul 12, 2019.
  1. Hi Guys,
    Just a quick one. Whats the recommended tyre pressure on the tyre placard for a 235/40/18 wheel?
  2. Same as any other car, you inflate than to pressure you need them to be at
  3. The plate says 30psi on Fronts, 29psi on rears for normal driving. I run mine slightly under these values.
  4. I run mine at 30 and 32, for normal driving, so just proves what I said lol
  5. I presume he asked because if your car came with the 19 wheels, it does not tell you on the sticker tyre pressures for 18 inch wheels
  6. Here you go mate, hopefully this will help!
  7. 30 and 29 seemed a bit low to me. I run 33 front and rear but i guess it's all personal preference.
  8. 31 front 30 rear...for many years on my R26.
    Tyres have always worn even across the tread.
