275 Tyre pressure sensor reset
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by Markkingmonkey, Dec 4, 2018.
  1. i bought a 275 trophy over the weekend which is awesome, the tyre pressure monitor is saying adjust pressures I have adjusted them and according to my compressor they have 2bar in each the car is registering 2.1 in the front 2.0 in the rear, on the door plate it specs the fronts to rear should b different can I save these pressures as is and reset the fault or do they have to match in the car for the fault to go?
  2. V basic system can’t save anything, stick 2.1 all round and drive it. The sensors will sort themselves out even if mix wheels up.
  3. Ok cheers
