Trolley jacks
Discussion in 'General Chat' started by deadmau5, May 10, 2015.
  1. I'm in need of a new trolley jack as my current one finally died.
    My main requirement is that it can get under a standard height R26 without needing to either drive onto blocks of wood or use the scissor jack first.
    Budget of up to £100 but lower if possible.
  2. As Grumpy Twig says. I have the older version of that and goes under a lowered car with no issues.
  3. Feirny
    Feirny RSM Admin
  4. Double post
  5. I bought that kit SGS sell for £129 with the 4 axle stands at Xmas, really good jack couldn't recommend one enough.
    Regarding jacking, one way I found easier with a lowered car, I bought some small drive on ramps from laser. About £40. They're only around 4 inches high maybe, but it gives you the extra room to jack from a different point under the car and then place the stands on the normal jacking point. Back is easy then
