Tracking results - Help
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by Robiniho77, Oct 14, 2014.
  1. Just been down to Brookspeed in Eastleigh and had them properly look at my tracking issue and they have said that its the rears that are out both out left, the fronts are fine.
    Anyone any ideas on this at all or seen it before?
    Thanks alot
    Liam
  2. I know on the mk2 megs, the rear beam was always a bit off to the left. I am not sure the reasoning for it mind you but it comes from the factory. Although you should be able to still dial the front in to compensate I would've thought!
