Tracking Help
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by Robiniho77, Sep 2, 2014.
  1. Im having some problems getting my car to run straight even after getting it tracked twice.
    The steering wheel wants to centre itself slightly left all the time and drifts that way on the motorway ect.
    Not sure what route to go down next.
    Could someone recommend me somewhere to take it to get it sorted properly as my local tyre place im sure is not the best..
    Thanks alot
    Liam
  2. Have you got your wheels balanced as well?
  3. Just to say before you go off too far. Try swapping wheels left to right in case tyres are very slightly out there is a tolerance but if both are wrong together in same direction it may cause this. Had problems before and proved this. Only slight though fortunately. Otherwise something may be distorted and my knowledge leave me.
    cheers Andy
  4. I'll second this, had the same issue on my Clio 200. Swapped wheels left to right and problem was solved.
  5. depending on the tyres, swapping left/right might be a bad idea, as they could have a rotation direction, and it would affect grip if wrong.. to check whether this is the problem, it would probably be alright though...
  6. mine does it....
    going to get a 4 wheel alignment done.
    i'll confirm whether that fixes it
