Morning all, I'm looking at replacing wheel bearing hub and wishbones.........How much torque is required to tighten up: E14 bolts that hold the wheel hub to the hub carrier Wishbone ball joint to the hub carrier Wishbone to subframe Thanks!
Has anyone got the torque settings for the rear end? Specifically the beam to chassis bolts, shock to beam bolts and caliper to carrier bolts?
The beam to chassis bolts are 105nm upper shock bolt is 62nm lower shock nut is 105nm slide pins bolts 35nm
