Torque on android
Discussion in 'Electrical & Interior - Security, ICE, Wiring Loom' started by DANNYF1985, Feb 6, 2014.
  1. Hi is any one using this if so does it work
  2. Ive used it a bit.
    All seemed to work ok for me although i didnt try out every function i was only really looking at boost and IAT
  3. yep, I have it and it works well.
  4. I used it too. Works well for me
  5. do you use the pro or lite version
  6. I use the Pro, I don't mind paying for something I think has been worthwhile and it's not a huge amout of money really.
  7. I use Torque Pro
  8. Use pro. Worth supporting the developer IMHO. Its a good app!
  9. What obd thingy do you all use? I couldn't get mine working.
  10. ELM327 BT (micro)
  11. I was talking about this with a friend at work. Can you leave the OBD dongle thingy in place all the time and close the panel I mean?
  12. Now with the one I bought. But that was the cheapest I could find
  13. ETA. It was an ELM 327 effort off ebay
  14. yes but then ELM still working. Now You can buy it with on/off switch :smile:
  15. Is it a problem if the ELM is still working? Other than people potentially being able to access it?
  16. Just a warning, the cheaper ELM's do not have a very good refresh rate so some of the dials in Torque pro will be slow to update, and not give you real time (ish) info.
  17. I think that is a OBD over bluetooth problem, not just limited to ELM. There is a wireless version on Kickstarter, but it's pretty pricey!
  18. Got my Bluetooth OBD II dongle through the post yesterday and downloaded the Torque app onto my Nexus 7 tablet.
    Biggest pain in the ar$e was getting the cover off to get access to the port!!! Once I'd plugged it in though, lights came on and paired up with the tablet no problem.
    Had a bit of a play about with it, clever how it picks up the revs and boost etc. Will need to sit down and play with it a bit more but bearing in mind my Nexus sits redundant most of the time now, it's handy. Plus it did show that at some point cylinder 2 had misfired so cleared that error and can keep an eye on that in future. :smile:
  19. How do you set the boost up on this thing. Mine always shows a negative reading.
    Is there a way of calibrating it?
  20. Will.
    Is it negative when on idle or when you're actually on boost?
  21. I can't get mine to talk to my car at all.
  22. Negative is expected, nothing to worry about. There is an explanation on the forum somewhere but I can't find it now.
  23. Is anyone produced this software for iPad / iPhone?
  24. Was wondering that myself I wouldn't mind a look at it is it like a poor mans scangauge ?
  25. Oil temp gauge
    Hi, in general it is working ok, but I'm wondering if anyone is able to get the oil temperature gauge working??
    Btw; there is an app for iPhone: Dashcommand
  26. Will.
    The ecu doesn't give you oil temp through the obd port.
  27. Yes but for cheap ELM 327 obd scanner you need to jailbreak your device and add roqybt for around £3-£5.
    i've done a video on how to use a cheap obd with harrys lap timer. BTW harrys laptimer for both iOS and android is a fantastic app
    You do the same for obd but obviously you would use your scanning software such as dash command
    [video=youtube;RWwWE8m19Rg]http://www.youtube.com/watch?v=RWwWE8m19Rg[/video]
  28. Windows phone!! :-(
  29. Hi got my torque app all running what should the boost be sitting on idle and when on full boost
  30. Ordered an ELM327 WIFI adapter for my car, got DashCommand on my iphone. Looks half decent. Will report back if/how well it works when it arrives.
  31. Might get one of these for myself.
    Would be interested on your thoughts of the DashCommand app and how well it works with the wifi adapter when you get it. Looks pretty good though, so hopefully it works well.
    Thanks.
