175 DCI timing chain cover gasket
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by tof73, Apr 13, 2017.
  1. Hi,
    i am about to change my timing chain and want to know if there is a replacement for the above mentioned or is it just silicone tube of sealant and some elbow grease?
  2. If it was my engine, I would go the silicone route. Can't go wrong.
    Why do you change timing chain?
    S.
  3. timing chain is rattly & noisy and engine does not start very well when cold, also the engine is not very happy looks like a misfire if you know what i mean,
    so am hoping a new timing chain will fix the later
  4. How many miles has it done ??? my 175 dci Grande Espace has 160K on the clock and on the same chain.
    I took the head off of my Megane Dci and put the cover back on with a good quality gasket making sealer.
  5. Mines done 150k and chain seems good.
    Maybe it's something else?
    RS 175 Cup Lux
  6. thanks for your replies, found that there is no gasket / seal sold by Renault, just used some Wynns gasket maker as Renault mentioned.
    Many thanks
