Thermostat
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by jack250, Feb 10, 2016.
  1. Does anyone know if you need to fit a new seal with a new thermostat on an rs250?
    Jack
  2. Hi Jack
    For the price of the seal it's a no brainer, if it leaks when you refit it you will have to strip it all again.
  3. nice one
  4. Just finished replacing the thermostat on my 250. Said i'd post a how-to once done so here's some info.
    Tools:
    8/10/12mm spanners/ratchet set (need an 8mm spanner to get the bolts off the thermostat itself, awkward to access)
    Method:
    Remove battery (I drew a diagram of where all the wires went just incase)
    Unclip the ecu (I presume this was the ecu.. the box with 3 plugs at the front of the battery casing) *remember where all plugs went
    Remove battery casing and surrounding attachments
    You will then see the thermostat (3 bolts attaching 2 pieces of metal bang on in the middle of the engine, do not get confused with the air flow pipe leading to the manifold towards the front of the engine)
    Proceed to remove bolts (very fiddly but persevere )
    Once removed you will lose a bit of coolant but not much
    Make sure you insert the new thermostat the way the old one came out
    Resemble everything (this is where the diagrams come in handy)
    I then left the car running with the cap off the coolant bottle for 20mins to get rid of any air in the system
    Let the car cool and then check how much coolant needs to go in
    Jobs a good en! Took roughly 2.5 hours.
    SCP likes this.
