Thermostat change 225
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Ashley, Nov 8, 2017.
  1. I'm going to be replacing the thermostat on my 225 is it just the 3 bolts holding the front housing on remove the old stat put new one in make sure it’s seated properly
    Bolt housing back on remove bleed screw
    Top up coolant until a constant stream is coming out of the bleed hole then tighten bleed screw
    With coolant cap off start engine let car get upto temp with heater on hot
    Topping up coolant then once upto temp screw coolant cap back on let idle check levels
    I’m not wanting to do a complete flush so didn’t know weather I had to remove the heater matrix bleed screw aswell as I’m only replacing the stat
    Coolant was changed 2 years ago
    Thanks in advance to any pointers or tips guys
