The noisy ball joint again
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by chumaxa, Dec 8, 2016.
  1. Hi guys, I had a dead ball joint on the passenger side 6 months ago, and now I think the driver side is gone as well, the -6 degrees killed it ... Problem is, I had the other one changed by Mark Black but did not get the invoice, and it is mission impossible to just reach him on the phone .. So could you just remind me if it is the upper or lower ball joint ? You know awfull lock to lock noise with very slow car pack speed ... Also, I need to replace the arb drop links, anything else I should do at the same time ? (bushes)
    And last question, I found some "roll noise" when braking with the new fitted front michelin PSS, so is it the tyre or something else might be faulty at the same time ?
    Cheers :smile:
  2. Michelin PSS can be quite noisy, especially on crappy roads.
  3. If you type in 'midland Renault specialist' into google his contact number is on there mate. He has a new landline number which he will answer
  4. I know his number, have been caling dozen times since last week, almost never pick up, and the info I needed takes 1 minute to get ....
  5. I am going to replace my passanger side ball joint in few hours at my friends local garage, i have the exact same problem. Do you managed to buy ball joint? if not i can get you good price just dont know how much is shipping from croatia to you?
