Temporary fix on engine mounts
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by coetseejj.rd, Jun 20, 2018.
  1. Have since replaced the upper torque dogbone mount and installed powerflex inserts on the other mounts.
    Engine mounts started to fail badly and funds were unavailable at the time to purchase new ones. So out came the jigsaw, carpet knife, contact glue and some ingenuity.
    Had a pilot sport 3 front bike tyre in the garage. Cut some inserts and glued them in place with contact glue.
    For the dogbone link I had to first cut the end of one side flush. Then used a hole saw to cut 3 circles in the tyres. Shaped them a bit with the knife and pressed them into the mount. Cleaned the sleeve and pressed it through. Finally screwed in 2 woodscrews into the sides where the movement on the mount is minimal.
    This fix was in the car for 2 months and when I got the Powerflex inserts they were still as good as when I made the inserts, even the torque link (now replaced).
    Tbh I can only feel a slight increase in rigidity since I fitted the powerflex inserts. The lower mount must still be replaced, but rebuilding the basic suspension components so wallet says it'll have to wait a bit.
    18cacbe4b21ea74d3d6d94adad4bc3f5.jpg 158624deaacf9b2aab4d3b798d6869eb.jpg f1f682c242a10e3f62ecc02af08d0746.jpg e8c9aa4ca66d37c0081048a6e508560c.jpg 35c4ea77455211367ae007003c9f9173.jpg cf6059e8ce6dc9095b4516a815694a89.jpg 915c828f1388ac3936ba7d5ae2fa0562.jpg 6ec3a70b0a5ecc8490ab95452a4767b5.jpg
    Sent from my ANE-LX1 using Tapatalk
    Big Uno likes this.
