Swivel bearing seals
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by Jimmy'srs, Apr 11, 2020.
  1. Hi guy's, does anyone know if swivel bearing seals are available at all from anywhere ?
  2. ianplymouth
    Yes, i got mine from a local bearing supplier
    https://www.premierpowerproducts.co.uk/
    JJZ likes this.
  3. Did you have a part number for them when you ordered ?
  4. ianplymouth
    No just gave them the sizes, i have some new ones in the workshop can measure them tomorrow for you if you want
  5. JJZ likes this.
  6. Yes please if you could measure new ones for size that would be great thanks
  7. ianplymouth
    Mossy has added above, sounds about right, been a while now as the 265 doesn't use them.
    But will check tomorrow as well
  8. Ok thanks
  9. ianplymouth
    Yes those sizes are correct
    I have two here if you are interested
  10. Yes was going to order 2 how much do you want for them ?
  11. ianplymouth
    £12 the pair posted
  12. They’re only £5 each posted on eBay and came within 2 days.
  13. Bumping an old thread but does the mk3 megane run the same bearing as the mk2? INA BK4520?
  14. ianplymouth
    No, totally different
    MK2 has the bearings and the MK3 has ball joints
    Aldo likes this.
  15. Bumping an old thread but do you need single lip or twin lip seals in the 45x52x4mm size for the BK4520-A swivel bearing?
  16. matt e
  17. Thanks Matt.
