Swirl pot, with separate pump.
Discussion in 'Wanted' started by oldfella, Dec 18, 2023.
  1. I am after a swirl pot, with a separate pump, NOT the combined one. Thank you.
  2. Hi Arthur
    Why do you want a swirl pot, what power are you running ???
    I just fitted a DW65c into the tank unit, worked it out that it's good for over 600hp, my R26 ran 405hp without any issues.
    Only thing i found was at Spa you have to keep the tank above 1/4, not had a problem elsewhere
