R26 Suspension/subframe part
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by Chris79, Apr 7, 2018.
  1. Hi mate, bit of a thread bump here. Ive ordered the lemforder bushes from mister auto.
    https://www.mister-auto.co.uk/control-arm-bush/lemforder/28879-01/
    and
    https://www.mister-auto.co.uk/control-arm-bush/lemforder/28878-01/
    which one of these 2 was the incorrect bore size. ive already ordered so will have to place a new order for the febi equivalent as per trophyboys post i think, but not sure which one of the bushes is the correct/incorrect one. I dont want to order febi equivalent for both bushes if at least one of the lemforder ones is ok.
    Hope that makes sense ive waffled bit there!
  2. Hi mate, the top one is correct, no idea what the bottom one is! Looks more like the rear beam bush! The part that was incorrect that I ordered was the lower rear bush which is different altogether than those.
    there’s actually a supplier on eBay of the correct lower arms complete for the r26. I’ll post a link up, they’re £75 each which is much more acceptable than the Renault items.
  3. Edit, bottom one is correct
  4. Thanks mate. Ive reordered the correct top one then, gone for a febi one as per trophyboys pictures. Hopefully negating the need to buy complete lower arms. Thanks for the help mate.
  5. No problem, let me know if you need anything else.
  6. Resurrecting an old thread as the relevant detail is here.
    Can anyone help me source the J brackets for the R26
    Specifically this PN: 8200364827
  7. Rpd or auto doc should have those in stock.
  8. Unfortunately not
