225 Sump oil leak
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Beast31, Oct 30, 2016.
  1. Does any have a tutorial on removing and replacing the sump
    Sent from my VIVO using Tapatalk
  2. ianplymouth
    It's a piece of cake, drain the oil and undo the bolts, i think there is about 20 of them, refitting is the reverse
  3. Do I need to remove the subframe on the right side
  4. But yeah I'll figure it out thanks
  5. ianplymouth
    No, you can remove without taking down the subframe, just need to remove the under tray.
  6. Ok then but what size torx bit do I need
  7. ianplymouth
    i am sure it's E8
  8. Thanks
