Strut removal?
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by CJ_RSport, Sep 6, 2013.
  1. CJ_RSport
    CJ_RSport RSM Moderator
    Any one know ifs its possible to remove strut without removing hub? Ie pushing hub down and pulling strut out been told the hubs gota come off :worried:
  2. yep thats right
  3. CJ_RSport
    Ok best get a 32mm socket then lol
  4. CJ_RSport
    What a nightmare haha pretty much everything siezed so heat gun game out and set of new nylons
    Dont fancy that in a hurry again
    But what a difference!!
  5. Post some pics Craig :wink:
  6. I have done them without removing the hub. It's not easy & you need 2 people & some spring clamps to get the damper out.
    If I were you I would take the hub off then you can inspect all the components. It's also worth replacing the swivel hub bearings at the same time.
    Lee
  7. CJ_RSport
    Will do was dark by time cleared up etc :smile:
  8. CJ_RSport
    I thought this was achievable but went the full route which wasnt difficult when we had some better tools
    The swivel hub bearing seemed fine im guessing the top bolt and bottom secure this into a bearing?
    Compo is due soon so fronts are having an overhaul soon anyway :smile:
