265 Strange dada noise when lift off throttle
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Junyan liu, Apr 9, 2023.
  1. Hi Gents,
    My 265 has some strange dada noise when lifting off the throttle. My car has a SMF conversion and it does pass some gearbox noise but this one is more like some loose parts swinging. I wonder if is the gearbox mount and engine mount.
    I recently changed the Coilover and removed and reinstalled the front suspension; they all look ok.
    Just want to know when it was stock, the gearbox was already "swinging" when changing gears quickly. Is it the normal stock gearbox mount feel?
    If I need to change all the mounts, can anyone please advise how to remove the following mount?
    1. the transmission mount. I assume I can change it by just remove the battery tray?
    2. bottom rear mount, It has a bracket with 3 bolts. How do I remove the third bolt?
    Much appreciate anyone who has gone through this.
    Regards
