R26 Sticky Clutch
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by wms_f1, May 1, 2016.
  1. Hi guys
    Just after some advice please. My R26 has started suffering from a sticky clutch over the last couple of days.
    Problem is when releasing the clutch after changing gear, as you pull you foot up the clutch pedal gets stuck half way up. It doesnt happen everytime, and I cant seem to get it to do it when I try to, but defo is an intermittent issue.
    Any ideas or had similar problems??
    Llifon
  2. I think i fell that before, it is the carpet that stuck on the middle
  3. Thanks for the reply.
    Its defo not the carpet.
    Anyone other thoughts?
  4. Anyone??
  5. MBC
    MBC
    Nope!
  6. Mine did the same for a while but has Stoped doing it it could be the slave cylinder ,clutch cable,release bearing or maybe bush at top of the clutch pedal arm.
  7. slave doesn't really give much warning, as I've found out twice in 2k.
  8. Thanks guys.
    How much of a pain is it to change the slave?
  9. Pig of a job, unless you are very handy with a spanner
  10. No im not that handy with a spanner can manage the basics but thats it!
    Will take it to a garage to have a look then me thinks!
  11. I'd be surprised if it's your slave mate
  12. Today the car has started juddering when pulling away in 1st gear!
    Any I right in thinking its possible new clutch time??
