R26 Sticking door handle
Discussion in 'Exterior & Bodywork' started by Dan-r26, Aug 11, 2013.
  1. I notice last night that my outside passenger door handle is a sticking when It is pulled it's not retuning
    How easy is it to get the handle off? It feels like a spring in side might be to fault? Also anyone know how much a new handle its just a normal one not a keyless
  2. Markblack@MRS
    Markblack@MRS RSM Trader
    A dash of wd40 will fix it
  3. Mine is doing this too. Wd40 won't work & neither does silicone spray.
  4. +1 this, 225 started doing this and WD40 sorted it straight away!
  5. Il try that tomorrow thanks
  6. Wd40 hasn't worked!
  7. Dan take the cover off and check the handle hasn't moved toward the back of the door ! Small screw just inside the door will aid in the cover removal :wink:
  8. Il try have ago later the handle does have a bit of play.
