Steering rack squeak
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by ghosty0101, Aug 13, 2015.
  1. I noticed when driving home that my steering rack has started creaking when I turn the wheel to the left, it sounds like an old spring! Is there something I can grease up or is something actually wrong with it?
  2. You can grease parts of it up . . . and could also fit a TFD bush . . .
    I actually have one of these spare because I left it (way) too long and had to replace the entire rack.
    I paid £33 I think, you can have it for a score inc. postage if you want.
  3. I have exactly the same issue with the squeaking. I have the TFD bush installed already. I started to build 2 opinions:
    - either the bush is doing the squeak
    - either the bush is not doing anything, but I need to grease something (question is what???)
    - either the steering rack is running on borrowed time
    Did anyone else had this kind of issues?
    S.
  4. Hi, has anyone else managed to fix this issue? Thanks
    Sent from my EVA-L09 using Tapatalk
