250 Steady whine, increase with speed
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by hsustyle, Aug 27, 2023.
  1. Gearbox whine.
    My 250 Cup has recently developed a whine ,most noticeable between 50-70mph where I spend most my time..
    It does this in gear AND in neutral and doesn't change by gear or engine speed, it's rotational and increases with vehicle speed.
    I've seen lots of similar posts, assuming gearbox or diff bearing but interested to hear what others think?
    Hoping it's just a wheel bearing but I can't really tell where the noise is coming from.
    66k miles, no paperwork for gearbox or clutch work.
    Video here
    https://youtube.com/shorts/f9FwKFPKvMA?si=RkodTPuJ2Htm0hMf
  2. Any luck with this ? My 265 has a similar whine at 70
  3. Sounds gearbox related, had the same on my 275.
  4. I ended up having the gearbox rebuilt by AW MOTORWORKS. Screenshot_20230918-123511.png
  5. Nice!
  6. autronix
    autronix RSM Club Member
    very "nice" .... I don`t have the wine but the gears are engaging like a pig. beside the usual bearings and some gears + gears clusters I also suspect some fork bending , etc.
    need to open and investigate ....
    so many bearings are worn like this , seems to be a common issue. maybe clereance issues , maybe low quality parts , oil , etc....
  7. autronix
    I ment whine not wine :flushed: .....
  8. also check exhaust manifold gasket + turbo gasket, when it's not a gearbox
  9. autronix
    today I removed the engine and gearbox. engine is striped down, and tomorrow I will open the gearbox too ....
    hsustyle likes this.
  10. autronix
  11. Not sure on what needs doing or what brand to use, I had mine done by a Renaultsport Specialist
    autronix likes this.
  12. ianplymouth
    I used SNR bearings, changed all the seals as well, but my supplier couldn't get one of the deals, so had to go to Renault for that, gearbox has been faultless since and i did a good few trackdays and running a lot of power and too
  13. autronix
    many thanks Sir! what oil to use ?
  14. ianplymouth
    75/90 fully Synthetic
