225 Starting a forge build after FCS
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by aarroncolley, May 18, 2016.
  1. As the above says I'm going to start my Megane 225 forge build after French car show.
    I'm goi to use wossner pistons and rods and obviously many other things to the engine. But my question is I ideally want close to 400bhp if I'm spending all this money could people give me ideas what sort of cams fuel system and more important what turbo I could use to get me to that bhp as I was going to use a 250 turbo but I don't know if it to produce that bhp.
    What spec of parts would people suggest. Every bit of help is much appreciated.
    Thanks Aarron
    MBC likes this.
  2. T20 Turbo
    KTR Racing Engine Mounts/Gearbox/Torque Mount
    3" Turbo Back Exhaust
    ARP Crankshaft Main Cap Stud Kit
    ARP Cylinder Head Stud Kit
    Crankshaft "Big End" Bearings King Racing
    Crankshaft "Main" Bearings King Racing
    PEC Forged "H-Beam" Con-Rod Set
    PEC Racing Forged Piston Set
    Replacement Oil Spay Jets
    Seimens Dekka 630 Injectors
    Uprated MLS " Multi Layer Steel" Head Gaskets 1.30mm Thickness
    Gates Powergrip Timing Belt Kit
    Auxiliary Belt and Tensioner Kit
    TTV Solid Mass Flywheel
    Genuine R26.r Clutch Including Slave Cylinder
    004 External Fuel Pump
    Swirl Pot
    All New Seals
    Pace Front Mount Intercooler ( 4" Core )
    Mocal Oil Cooler
    Thats my engine spec
  3. Cheers for that mate really helpful. What bhp are you putting out with that set up. Also the auxiliary kit I'm going to go Renault for that or have you used after market uprated ? And I was also going to use wossner pistons and rods nearly 1k for the both are the ones you've used better or do you think wossner are good ? Thanks for your help mate
  4. I only use Gates belts mate.
    And it should make 350+ with decent mapping, should find out tonight! Wossner iv heard are really loud on tickover. Not to sure why.
  5. Is there much in price difference in the Pistons you've got and wossner ones ? Could you inbox me your number if you don't mind lol just want to get the best parts for my engine build. Thanks bud
  6. Done mate
  7. Sorry mate I don't know if my inbox was full it came through but then when I went into inbox it's not coming up
