250 STARK oilfilter
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by lurius, Jul 24, 2019.
  1. Hi, today I fitted a STARK oil filter. The filter is shorter than the original. Was unsure when I checked the structure of the filter inside, the pipe down against the check valve almost closes tightly to the outlet/inlet pipe on the engine. My question is, has anyone else tested this one without any problems?
    https://www.autodoc.co.uk/stark/7989132
